QUOTE(tails @ Apr 30 2006, 08:03 AM) [snapback]1804428[/snapback]
im using window xp right i went to control panels like you said but i cant not find vietnamese input in the drop down list
Check again
Windows XP and Language SetupNote This documentation is for Windows XP and works with the French, Italian, Spanish and Vietnamese languages. It will NOT work with Chinese, Japanese or Korean.
Windows XP Setup:
From the Start Menu, go to 'Settings'.
Click on 'Control Panel'.
Double Click on the "Regional and Language Options" control panel.
On the top there are three tabs. Click on "Languages"
Click on the "Details" button.
In the frame that says "Installed Services" click on the "Add" button. The "Add Input Language" dialog box pops up.
Scroll down the language menu until you see the language of your choice and click. Then click 'OK'.
When that box disappears, you are back to the original dialog box. Click OK as many times as necessary to get out of it.
Look at taskbar on the lower right hand corner of your screen. Look for a small dark blue box with the letters "EN" on it.
click the box, then click on "VI" and make sure when you are done, the dark blue box says "VI".
You can now type in Vietnamese using Internet Explorer, Microsoft Office, and a host of other programs...
Note: This assumes that during the initial install of Windows, the appropriate language packs were installed properly. If they were not, you must install them before the above instructions will work.
