Full Version: Canon EOS-IV camera and EF28 ~ 70f/2
Asia Finest Discussion Forum > Asian Culture > Singapore Chat
nederland12
Canon EOS-IV camera and EF28 ~ 70f/2.8L USM Lens
peak in 440Tlm and 64 m, with two handsome low reflection to balance the CCO value. This multi-layer anti-reflection film is also known by the anti-green film. The surface of single and multilayer antireflection film after the initial set. Together with the base of transmittance, transmittance layer combination calculation. Calculated from 37Ohm-68Ohm each point of the points for the 10nm spectral transmittance,franklin marshall sale, and calculate the CCI value for white light transmittance through on 440nm, 49 ~ nm, 590nm, 66Ohm weighted four-point approximation of the transmittance If white light transmittance values ??obtained up to design specifications is not thistle, Liu consider increasing the number of multi-layer membrane surface; if more than indicators, then reduce the number of multi-layer anti-reflection film surface than the design requirements of the general rate of 10% by white As a margin around the saddle as appropriate. For CC [value adjustment. By changing the single-layer anti-reflection film of the center wavelength and multi-layer anti-reflection film of the center wavelength of reflection peaks corresponding to the peak value and to achieve. Single-layer anti-reflection film's design,abercrombie düsseldorf, a central wavelength of one of the best icosahedral consistent to facilitate the implementation process. The completion of the work,franklin marshall bruxelles, is only a preliminary design of the membrane system operability how, but also for a large number of simulation,abercrombie dundrum, simulation of the coated film in the deviation,uggs online bestellen, the value of the total transmittance and the impact ? to the CCI, amount of tolerance of the membrane obtained. Preliminary identification of the entire group before the lens coating. 4 Department of correction film coating system design is completed, even after pre-production through the lens of the whole group to test the value of system parameters on the film that made the whole,uggs outlet, correct. Until the actual product to design specifications. Can be considered complete coating design of the author's F70-210m [13 zoom lens coating design in Si and for F28-105mm zoom lens coating and re-checking design. On the use of the above methods and ideas. Above if inappropriate,abercrombie münchen, please criticize the correction. Period of 2000 u 25 with standard photographic camera lens CCI value instance Thailand two long transmission wGWratWRWR10.231O. 230.421O. 4239006031804000745184100838304200881210560011210. Maggot 44O094l312 +22460 n95l31235460097l2l] 6447009887894008480O. 9843 +. 20g80.9821.980 ? 5000.991O992lg8O. 99ll004o05201005555301 +0088 o054Ol [lIl15OO1O02525001l0010013130Ol1O057010013l300100l0009.002 deleted 5900 2003297 (iv) 0 ? 0993966100 ? 659462009887.84O0812ll76 ix 097l0l843650096222ll2660096I6l636 (iv) 09538o68o0941004 = (Wt] 893699909734lqwtl062O0l99 minus 1 Chia-color contributions to Mulberry 195 000 005 004 Index: 0/5/4 on the next younger brother of 15) 4 wrapped like the image plane illumination uniformity surface location 62849 as surface illumination uniformity 22.618346753l104I34f28mm22.618246753ll07134 on. 5% 226l83467532IO9l35256282I43.2495240247f70ram25643249523824.855 +3% 282432495237248 Table 4 in the lateral part of the test apparatus 1,peuterey 2012,6,27,abercrombie madrid,28,49 and 54 receiving surface 54 ten points uniformly distributed address code, which 1,abercrombie dublin,6,49 and 54 representatives of the four corners of the edge points. 27 and 28 for the center of each focal length three times removed. Calculated as the average surface after the illumination uniformity ratio of 3 tone Pina transfer function lMTF) camera lens lens modulation transfer function is a measure of quality of ten key indicators that can provide more resolution than the camera information, has been widely used in the lens design, production and testing evaluation. Prince Yu n is EF2g-7Ommi / 2] m Sapporo lens f28n that when the system transfer function (MTF) measured curve. The best lens aperture measurements too,abercrombie hamburg, figure axis is outside the field of view angle 10: when the addition. The only measured focal length of Canon EF28-70mmf/28L i2940-6944nmai28m, al stray light when the coefficient of 1.8%; f70mm when the stray light ratio is 15%. (Editing Xieyong Zhong,
Related articles:
    block based blind detection watermarking mean
Related articles?
Canon EOS-IV camera and EF28 ~ 70f 2
Lawrence of - Pentax 67 medium format camera
APS cameras use the specificity of
occafroma
Drug Abuse Symptoms Shaking , http://permasmile.net/ - phentermine 37.5 no prescription The medication is prescribed to help obese patients lose weight. cheapest phentermine
