Full Version: Looking young - diet or genetics?
Asia Finest Discussion Forum > AF Entertainment > AF Lounge
samnang
I'd say it's likely more genes. All the healthy food and supplements in the world won't help you if you got $hit genes.
And I think I got some good ones. 25-years-old and not a wrinkle on my face. But I see plenty of others my age with huge wrinkles on their foreheads and around their eyes.
QSC
QUOTE (samnang @ Dec 5 2011, 04:35 PM) *
Genetics is the determining factor on the human body structure. It is one of the few topics many choose not to embark. Having good genetics is not common amongst the majority of people.
tienuecep
I began with 7-10 BM's each day. Couldn't try to eat basically were required to start working or perhaps out your front door. My partner and i resided this way coming from February to be able to October. My personal Generate. explained I had been lactose-intolerant. Last but not least following 8-10 several weeks My spouse and i known as as well as suggested I desired some respite. I needed a colonoscopy and yes it was established I had created cologinous colitus. I used to be wear Entecort for 3 weeks and also extra Asacol the very last 30 days. I've had a number of flair ups since but proceeded to go nearly one year with no. I feel I am very fortuitous for the reason that our negative effects are generally minimum.
Absolutely no negative effects -- apart from inside my 3rd width, if we couldn't obtain the diarrhea manageable utilizing both prednisone and Asacol, it turned out that the particular Asacol was actually resulting in the diarrhoea. So now it has to become a garbage shoot - who knows whether or not it would have been a silver bullet, finishing the looseness of, cramping along with discomfort and providing me personally again playing, or something that keeps me stuck in the home, unable to threat relocating not even close to the particular bob.
I tried to understand precisely how Asacol operates and question if it's way too non-specific when i comprehended that it must be made to obstruct the creation of a natural lipid centered secretion referred to as prostaglandins, many of which result in infection however some that in addition inhibit infection. Here's a site that will explains a modicum of that will: Asacol Thanks everyone to the manages regarding the elimination failure and baldness. Horrible!
I have had some weight obtain since i have moving on asacol. It's assisted the actual looseness of not sure only have experienced others. We are upon alot of treatments pertaining to other conditions.
asacol side effects uk
asacol side effects kidney
asacol side effects medication
tienuecep
after stoping asacol almost all negative effects subsided i averaged about One particular significant style upward each and every 2 years using asacol so good for pretty much hemorrhage out Some years ago Simply can't consider the negative effects anymore i possibly could rarely make a closed fist devoid of finding yourself in discomfort as a fireman my partner and i keep men and women existence in my arms.
Excellent medicine however annoying to need to consider so much
Many of the widespread side effects regarding Asacol tend to be some tips i experienced before I started using that, and they largely persisted. Nonetheless, a year following taking place it, inside lose heart in a very undesirable spot involving belly issue, I started visiting a medical herbalist and that he increased concerns greatly. We now have produced gout pain, inside complete deficiency of the standard causes including burgandy or merlot wine along with red meat, and still have found it outlined as being a side effect. The actual herbalist turned for you to focusing on your gout symptoms as well as the intestine signs and symptoms less difficult worse : that leads me to consentrate which Asacol has never helped just as much as the particular herbalist and it has possibly offered us gouty arthritis. Herbalist has returned about the stomach point and I'm gonna come off your Asacol. That gave the impression to support a lttle bit yet has obviously been recently outdone by natural options.
Absolutely no key negative effects hair loss somewhat however place made that first move to genes!
asacol side effects insomnia
asacol side effects long term use
Mizz_Luv3r
Well, these days, we have all sorts of shots, surgeries, and creams to fight off aging. I think it's a combination of both.
devils666
QUOTE (samnang @ Dec 5 2011, 03:35 PM) *
I've noticed that people with dark hair and brown eyes age better regardless of race.
There's a reason why some genes are recessive and others are dominant. The darker phenotype is obviously a lot "heartier".
LittleDeathAngel
Sadly, I fall into the "look older than you are" category. x_x
So sad....
samnang
I do kinda wonder about the aging effects low carb diets have on people.
High blood sugar (caused by excessive consumption of carbs) is really, really toxic. It causes damage and inflammation all throughout your body. In fact, it's the true cause of heart disease: when your heart valves are damaged by high blood sugar, your body sends cholestral to repair the damage. Over the years, all those cholesterol repairs cause clogging.
Anyway, if you're spared all that damage (by low carb dieting), it might help you better retain your youth.
I've been low-carbing for about a year and it feels like my skin is more smooth and firm than it was previously. I used to have bad acne and other skin problems (i.e. keratosis pilaris), but now it's mostly cleared.
radiostar
I think it's mainly genetic but diet definitely is an important factor as well as environment. It's also more of how you are feeling (younger or older) and act that shows your relative age. By relative I mean the way a person appears to other people. It's your way of asserting your youthfulness.
